Install Your Switch
Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
Extreme Networks switches fit into standard 19-inch equipment racks.
A four-post rack-mounting kit is provided with the switch. A two-post kit can be ordered separately.
The installation process includes the following tasks:
Table 1. Switch Installation Tasks
StepProcedureDescription
1What You Will Need for the Installation Prepare to install the switch
2 Attach the Switch to a Rack or a CabinetInstall the switch in the rack.
3Install Expansion Modules Install expansion modules.
4Install Optional Components Install optional components: optical transceivers and cables.
5Install Internal Power Supplies Install one or two power supplies if your switch does not come with an installed internal power supply.
6Connect Network Interface Cables Connect network interface cables.
7Turn on the Switch Power up the switch.
8Activate and Verify the Switch Perform initial network connection and configuration.
