Remove and Replace Components
Use the information in the following topics to remove or replace components.
VIMs and SSDs are not hot-swappable, and the switch must be disconnected from its power source before replacing these components.
For each switch, ensure that all installed power supplies and fan modules have the same front-to-back airflow direction.
