An access point (AP), a controller, or a service platform uses the adoption process to discover available APs or peer controllers and service platforms. Adoption configurations are used to establish an association and provision the requesting device. Configure and support adoption settings within a profile and apply the settings to other APs supported by the profile.
At adoption, an AP solicits and receives multiple adoption responses from controllers and service platforms available on the network. These adoption responses contain loading policy information the AP uses to select the optimum controller or service platform for adoption. By default, an auto provisioning policy generally distributes AP adoption evenly among available APs, controllers, and service platforms. Modify existing adoption policies or create a new one as needed to meet the adoption requirements of a device and their assigned profile.
Use this procedure to configure or edit Adoption settings for a device profile.
If you want to override Adoption settings for a specific device, go to Devices, select the target device, then configure or edit settings as described in this procedure..| Parameter | Description |
| VLAN | Select VLAN to include a VLAN that the AP's
associating controller can reach. Use the spinner controller to set a VLAN between 1 and 4,094. |
| Preferred Group | Set an optimal group for the AP‘s adoption. The name of the preferred group cannot exceed 64 characters. |
adjacent to a column heading to sort the
data by the heading topic. By default, the data is sorted in ascending
order, as indicated by the direction of the arrow in the icon
. Toggle the icon to sort the column data in
descending order
. The "1" indicates by which column heading
topic the data is currently sorted.| Parameter | Description |
| Host (IP Address) |
Choose from the following options:
| Pool | Set a pool of either 1 or 2. The target controller or service platform belongs to this pool. |
| Routing Level | Define a routing level (either 1 or 2) for the link between adopting devices. |
| IPSec GW (IP Address) |
| IPSec Secure | Select this option to provide IPSec secure peer authentication on the connection (link) between the adopting devices. This option is not selected by default. |
| Remote VPN Client | Select this option to establish a secure controller link using a remote VPN client. |
| Force | Select this setting to create a forced link between an AP and adopting controller, even when not necessarily needed. This setting is not selected by default. |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
