Device Profile - Policies Configuration
User defined profiles can be customized and assigned or automatically assigned to access points using an AP Auto-Provisioning policy. User defined profiles should be utilized in larger deployments when groups of devices (on different floors, buildings or sites) share a common configuration. Each default and user defined profile contains policies and configuration parameters. Changes made to these parameters are automatically inherited by the devices assigned to the profile.
You can override the policy settings assigned to a device profile by configuring the same settings at the device level. Go to Devices <select a device> Policies.
Configure policies parameters for a device profile:
  1. Go to Profiles <select a device profile> Policies.
    Configure the device profile Policies parameters as described in Device Profile - Policy Parameters.
    Table 1. Device Profile - Policy Parameters
    ParameterDescription
    Management PolicySelect a Management Policy to assign to the device profile. The default setting is default.
    A management policy is a mechanism to allow or deny management access for separate interfaces and protocols (HTTP, HTTPS, Telnet, SSH or SNMP). Management access can be enabled or turned off as required for each policy
    Firewall PolicySelect a Firewall Policy to assign to the device profile. The default setting is default
    RADIUS Server PolicySelect a RADIUS Server Policy to assign to the device profile. The default setting is none.
    A RADIUS Server policy provides customized, profile specific, management of authentication data such as username and password.
    Event System PolicySelect an Event System Policy to assign to the device profile. The default setting is none.
    An Event System Policy allows the profile to capture system events and append them to a log file.
    DHCPv4 PolicySelect a DHCPv4 Policy to assign to the device profile. The default setting is none.
    Captive Portal PolicySelect a Captive Portal Policy to assign to the device profile. There is no default setting. If no policy is selected, no captive portal policy is assigned to the profile.
    Bonjour Gateway Forwarding PolicySelect a Bonjour Gateway Forwarding Policy to assign to the device profile. The default setting is none.
  2. Configure Auto-Provisioning Policy parameters as described in Device Profile - Auto-Provisioning Policy Parameters.
    Table 2. Device Profile - Auto-Provisioning Policy Parameters
    Auto-Provisioning PolicySelect an Auto-Provisioning Policy to assign to the device profile. The default setting is none.
    At adoption, an AP solicits and receives multiple adoption responses. These adoption responses contain preference and loading policy information the AP uses to select the optimum controller or access point for adoption. By default, an Auto-Provisioning policy generally distributes AP adoption evenly amongst available adopters.
    Use NOC Auto-Provisioning PolicySelect this option to use the NOC‘s auto-provisioning policy instead of the policy local to the controller or service platform. The NOC is an elected controller or service platform capable of provisioning all of its peer controllers, service platforms and adopted devices.
    Options are No, Yes, and Always. The default setting is No.
    Learn and Save Network ConfigurationSelect this option to allow the controller or service platform to maintain local configuration records of devices requesting adoption and provisioning. This feature is enabled by default
  3. After you have completed configuring the settings, choose from the following actions:
    1. Select Revert to restore default settings or restore the last saved settings.
      You cannot restore default settings after applying or saving changes.
    2. Select Apply to commit the configured settings.
      This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
    3. Select Save to commit and save the configured settings.
      If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
