Use this procedure to configure a new WLAN.
- Go to Wireless.
- Select
to
create a new wireless network configuration. - Configure the Rule parameters as
described in Wireless
Parameters.
Table 1. Wireless
Parameters| Parameter | Description |
| Wireless Name | Assign a name to the WLAN. |
| SSID | Assign a SSID (Service Set IDentifier) to the
WLAN. |
- Optionally, select the
Copy
From checkbox and choose an existing WLAN from which to copy the
configuration settings.
- Select Add.
- Configure WLAN parameters under
the Basic, Security, and
Client Load Balancing tabs, as necessary.
If you exit the wireless network configuration without first adding and
saving any basic or security settings, the configured WLAN persists, but
only until you log out.
