A Denial of Service (DoS) attack is an attempt to make a computer or network resource unavailable to its intended users. Although the means to carry out a DoS attack will vary, it generally consists of a concerted effort of one or more persons attempting to prevent a device, site or service from functioning temporarily or indefinitely.
Most DoS attacks involve saturating the target device with external communications requests so it cannot respond to legitimate traffic or respond so slowly the device becomes unavailable in respect to its defined data rate. DoS attacks are implemented by either forcing targeted devices to reset or consuming the device‘s resources so it can no longer provide service.
To configure or modify a Firewall DoS policy:
If you want to modify DoS settings, go to Policy > Wireless
Firewall > Firewall
Policy, then select
adjacent to the policy you want to modify.
Proceed to the next step, and modify the DoS settings in accordance with
the steps in this procedure.
| Parameter | Description |
| Event | Lists the name of each DoS attack type. See Firewall DoS Event Descriptions for a detailed description of each attack type. |
| Enable | Select Enable to set the firewall policy to filter the associated DoS attack based on the selection in the Action column |
| Action | If a DoS filter is selected, chose an action from the
drop-down list box to determine how the firewall policy
treats the associated DoS attack
| Log Level | Select to enable logging to the system log. Then select a standard Syslog level from the Log Level drop-down list box |
| Info | Additional information about the DoS firewall setting |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
Section contents:
