Go to Wireless.
The Wireless dashboard includes:
The Wireless dashboard displays a list of all configured WLANs in tabular form. The total number of WLANs is shown in parentheses.
Wireless Dashboard Column Headings describes the type of information displayed under each column in the table.
| Column Heading | Description |
| Name | Displays the name assigned to each available WLAN. |
| Status | Lists each WLAN's current status as follows:
| SSID | Displays the SSID assigned to the WLAN when created or last modified. |
| Encryption | Displays the name of the encryption type each listed WLAN is using to secure its client membership transmissions. None is listed if encryption is not used within this WLAN. Refer to the Authentication column to verify that there is some sort of data protection used with the WLAN or risk using this WLAN with no protection at all. |
| Authentication | Displays the name of the user authentication scheme each listed WLAN is using to secure its client membership transmissions. None is listed if authentication is not used within this WLAN. Refer to the Encryption column if no authentication is used to verify there is some sort of data protection used with the WLAN or risk no protection at all. |
| VLAN(s) | Lists each WLAN's current VLAN mapping. Mapping a WLAN to more than one VLAN is permitted. When a client associates with a WLAN, the client is assigned a VLAN by load balance distribution. The VLAN is picked from a pool assigned to the WLAN. Keep in mind however, typical deployments only map a single VLAN to a WLAN. The use of a pool is strictly optional. |
| Forwarding Mode |
Lists each WLAN‘s current bridging mode as either:
The default setting is Local. |
Choose from the following actions:
adjacent to a column heading to sort the data by
the heading topic. By default, the data is sorted in ascending order, as
indicated by the direction of the arrow in the icon
Toggle the icon to sort the column data in descending order
The "1" indicates by which column heading topic the data is currently
sorted.
