Go to Policies > Bonjour Gateway. Select either Discovery Policy or Forwarding Policy.
Configuring Bonjour Gateway policy consists of configuring discovery policies, forwarding policies, and rules. The user interfaces used to perform these configuration tasks include:
Discovery and Forwarding Policy List Column Headings, Discovery Rules List Column Headings, and Forwarding Rules List Column Headings describe the type of information displayed under each column in the user interfaces used to perform Bonjour Gateway policy configuration tasks.
| Column Heading | Description |
| Policy Name | Displays the name assigned to the policy. |
| Service | Displays the service that can be discovered by the Bonjour Gateway. |
| VLAN Type | Identifies whether the configured Service VLANs are either local or tunneled. |
| Service VLANs | Identifies the VLAN(s) on which the selected service is discoverable. |
| Instance Name | Displays the instance name (if configured) that the Bonjour service uses in its query of services to be dicovered. |
| From VLANs | Displays the VLAN(s) or VLAN alias where the Apple services are available. |
| To VLANS | Displays the VLAN(s) or VLAN alias where clients for the services are available. |
| Rule Id | Identifies the unique ID assigned to the rule. |
Choose from the following actions:
adjacent to a column heading to sort the data by the heading topic. By default,
the data is sorted in ascending order, as indicated by the direction of the
arrow in the icon
. Toggle the icon to sort the column data in
descending order
. The "1" indicates by which column heading topic
the data is currently sorted.
