Add a new device or edit an existing device basic configuration.
Device Overrides option is selected by default to ensure that device configurations receive periodic refinement automatically.| MAC Address | Device MAC addressed assigned when adding the device. This field cannot be edited |
| Type | Device type selected when adding a device. This field cannot be edited |
| Name | Device name assigned to the selected device. Type or modify the device name using the Name field |
| Site | Device location. Use the drop-down list box to select a device site location |
| Profile | Assign a profile to the selected device. Profile allows admins to assign a common set of configuration parameters and policies to controllers, service platforms, and access points. Use the profile drop-down list box to assign a profile for the device |
| Area | Assign the physical area where the device is deployed. This can be a building, region, campus or other area that describes the deployment location |
| Floor | Assign the target device a building Floor name representative of the location the access point, controller, or service platform was physically deployed. The name cannot exceed 64 characters. Assigning a building floor name is helpful when grouping devices within the same general coverage area |
| Floor number | Assign a numerical floor designation with respect to the floor's actual location within a building. The default setting is first floor (1). |
| Latitude | Set the latitude coordinate where devices are deployed within a floor. When looking at a floor map, latitude lines specify the eastwest position of a point on the Earth's surface. The exact location of a device deployment can be ascertained by aligning the latitude and longitude points on the earth's surface |
| Longitude | Set the longitude coordinate where devices are deployed within a floor. When looking at a floor map, longitude lines specify the north-south position of a point on the Earth's surface. The exact location of a device deployment can be ascertained by aligning the longitude and latitude points on the earth's surface |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
