The general system information diagnostics provides graphical representation of the
system health, including, central processing unit (CPU) usage, memory usage, disk
usage, temperature, fan speed, and RAID status.
CPU
Usage
Real-time representation
of CPU usage through a red line graph. Hover over the graph to view the
CPU usage percentage.
Memory
Usage
of memory usage through red line graph. Hover over the graph to view the
memory usage percentage.
Disk
Usage
disk usage percentage.
Temperature
Line graph of device
temperature.
Fan
Speed
Line graph of fan speed
for a device.
RAID
Status
Status of physical
drives.
Red means device
is offline
Green means
device is online
Alarm
Last checkin -
time when device was last checked in
Size - device
drive size
Type - device
type
State - device
state
PSU
Status
Read only information
showing device location, status, and device type.
CDP Neighbors Diagnostics
CDP neighbors provides read-only information about device CDP diagnostics. Use the
CDP device columns to view the following information:
Device ID
Platform
Local interface
Port ID
Duplex
Capabilities
Advertised version
IP address
Native VLAN
Version
TTL
LLDP Neighbors Diagnostics
LLDP neighbors diagnostic provides read-only device LLDP information. Use the device
LLDP column option to view the following information:
Chassis ID
Device ID
Platform
Capabilities
Enabled capabilities
Local interface
Port ID
Port description
Management addresses
TTL
Tasks Diagnostics
The task diagnostics is a read-only grid providing the following information:
Name
CPU %
Memory %
PID/PPID
RSS size
Status
View the per task graphs for CPU usage and memory usage as a line graph.
