To add or delete static route for a device:
The window displays a list controllers and access points within the managed network.
adjacent to a column heading to sort the data by the heading topic. By default,
the data is sorted in ascending order, as indicated by the direction of the
arrow in the icon
. Toggle the icon to sort the column data in
descending order
. The "1" indicates by which column heading topic
the data is currently sorted.
| Network Address | Add network IP addresses and network masks. |
| Gateway | Enter the Gateway IP address. This is the gateway used to route traffic to the specified network. |
| Static Default Route Priority | Use the spinner control to set the priority value (1 - 8,000) for the default static route. This is weight assigned to this route versus others that have been defined. The default setting is 100. |
| DHCP Client Default Route Priority | Use the spinner control to set the priority value (1 - 8,000) for the default route learned from the DHCP client. The default setting is 1000. |
| Enable Routing Failure | When selected, all configured gateways are monitored for activity. The system invokes failover to a live gateway if the current default gateway becomes unusable. This feature is enabled by default. |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
vx9000-3C6F18(config-profile-default-profile)#ip default-gateway priority dhcp-client <1-8000>
