A user pool defines policies for individual user access to local controller or service platform RADIUS resources. User pools are a convenient means of providing RADIUS resources based on the pool's unique permissions (temporary or permanent). A pool can contain a single user or group of users.
To configure a RADIUS user pool and unique user IDs:
| Setting | Description |
| User ID | The unique string identifying this user. This is the ID assigned to the user when created and cannot be modified with the rest of the configuration |
| Password | The password cannot exceed 32 characters. Select the show icon to view the password‘s character string |
| Group | Select a group from existing group list |
| Guest User | Use the toggle to assign guest user access. This determines if a user has temporary permissions to the local RADIUS server. Selecting the guest user access option will open guest user settings |
| Email ID | The Email address (in 64 characters or less) of the client user (user ID) requesting authentication validation to the controller or service platform using this user pool |
| Telephone | The 12-character maximum telephone number of the client user (user ID) requesting authentication validation to the controller or service platform using this user pool |
| Guest User Settings | |
| Start Date | The month, day, and year the listed user ID can access local RADIUS server resources |
| Start Time | The time the listed user ID can access local RADIUS server resources. The time applies only to the range defined by the start and expiry date |
| Expiry Date | The month, day, and year the listed user ID can no longer access local RADIUS server resources |
| Expiry Time | The time the listed user loses access to RADIUS server resources. The time applies only to the range defined by the start and expiry date |
| Access Duration | The amount of time a user is allowed access when time-based access privileges are applied. The duration cannot exceed 365 days. Select Till Expiry to keep the access duration the same as the expiry date |
| Data | The total amount of bandwidth available for each guest
user. Options include:
