Network Time Protocol (NTP) manages time and network clock synchronization within the network. NTP is a client or server implementation. Controllers, service platforms, and access points (NTP clients) periodically synchronize their clock with a main clock, which is an NTP server.
| NOC Update Interval | Specify the interval at which statistical updates are sent by the RF Domain manager to its adopting controller (the NOC controller). Enter a value in the range 5–3600 (seconds), or enter 0 to invoke auto mode where the update interval is automatically adjusted by the controller based on load information. The default value is 0. |
| Server IP | Set the IP address of each server added as a potential NTP resource |
| Key Number | Select the number of the associated authentication peer key for the NTP resource. The key number range is between 1 to 65,534, and 1 is the default key number |
| Key | Type a 64 character maximum key used when the autokey setting is set to false or deactivated. Select the show option to view the character string for the key |
| Version | Use the spinner control to select a version between 0 to 4. The default version is 0 |
| Minimum Polling Interval | Use the drop-down list box to select minimum polling interval. After the interval is set, the NTP resource is polled no sooner than the defined interval. Options include 64, 128, 256, 512, or 1024 seconds. The default setting is 64 seconds |
| Maximum Polling Interval | Use the drop-down list box to select the maximum polling interval. After the interval is set, the NTP resource is polled no later then the defined interval. Options include 1024, 2048, 4096, or 8192 seconds. The default setting is 1024 seconds |
| Preferred | Select Preferred to make the server settings the preferred setting for NTP servers |
| Autokey | Select Autokey to generate a key for the NTP server |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
