Go to Profiles <select a device profile> .
You can override configured Bridge VLAN profile settings for a specific device. Go to Devices <select a device> .The Bridge VLAN window includes:
The Bridge VLAN window displays a list of all configured Bridge VLANs in tabular form.
Bridge VLAN List Column Headings describes the type of information displayed under each column.
| Column Heading | Description |
| VLAN | Displays the numerical identifier defined for the Bridge VLAN when initially created. |
| Description | Displays the description of the VLAN assigned when it was created or modified. |
| Edge VLAN Mode |
Identifies whether the VLAN is currently in edge VLAN mode, as follows:
| Trust ARP Responses |
Identifies whether Trust ARP Responses is enabled, as follows:
| Trust DHCP Responses |
Identifies whether Trust DHCP Responses is enabled, as follows:
| IPv6 Firewall |
Identifies whether IPv6 Firewall is enabled, as follows:
| DHCPv6 Trust |
Identifies whether DHCPv6 Trust is enabled, as follows:
| RA Guard |
Identifies whether RA Guard is enabled, as follows:
Choose from the following actions:
adjacent to a column heading to sort the data by
the heading topic. By default, the data is sorted in ascending order, as
indicated by the direction of the arrow in the icon
Toggle the icon to sort the column data in descending order
The "1" indicates by which column heading topic the data is currently
sorted.
