Configure Message Logging settings for a selected device:
| Enable Message Logging | Select this option to enable the device to log system events to a log file or a syslog server. Selecting this check box enables the rest of the parameters required to define the device‘s logging configuration. This option is disabled by default. |
| Remote Logging Host | Select Add to create a table to define numerical
(non DNS) IP addresses and ports for up to three external
resources where logged system events can be sent on behalf
of the device. Select Add to add a new IP address. Select the
delete icon |
| Facility to Send Log Messages | Use the drop-down menu to specify the local server (if used) for device event log transfers. |
| Syslog Logging Level | Select this option to enable Syslog Logging Level. Use the drop-down list to assign a severity level to log events based on criticality. Event severity coincides with the syslog logging level defined for the device. Severity level options are Emergencies, Alerts, Critical, Errors, Warnings, Notifications, Informational and Debugging. The default logging severity level is Warning. |
| Console Logging Level | Select this option to enable Console Logging Level. Use the drop-down list to assign a severity level to log events based on criticality. Event severity coincides with the syslog logging level defined for the device. Severity level options are Emergencies, Alerts, Critical, Errors, Warnings, Notifications, Informational and Debugging. The default logging severity level is Warning. |
| Buffered Logging Level | Select this option to enable Buffered Logging Level. Use the drop-down list to assign a severity level to log events based on criticality. Event severity coincides with the syslog logging level defined for the device. Severity level options are Emergencies, Alerts, Critical, Errors, Warnings, Notifications, Informational and Debugging. The default logging severity level is Warning. |
| Forward Logs to Controller | Select this option to enable Forward Logs to Controller. Use the drop-down list to assign a severity level for forwarding event logs to the controller. Log level options are Emergencies, Alerts, Critical, Errors, Warnings, Notifications, Informational and Debugging. The default logging severity level is Errors. |
| Time to Aggregate Repeated Messages | Define the increment (or interval) system events are logged on behalf of the device. The shorter the interval, the sooner the event is logged. Define an interval in seconds (0 - 60) or in minutes (0 -1). The default value is 0 seconds. |
You cannot restore default settings after applying or saving changes.
This does not permanently save the settings you configured. If you perform a Reload (warm reboot), applied settings will be lost.
If you do not select Apply or Save, the settings that you configured are not saved when you move away from the configuration window.
