View mesh point statistics for member APs and their connected clients.
| Hostname | Displays the administrator assigned hostname for each configured mesh point in the mesh network |
| MAC Address | Displays the MAC Address of each configured mesh point in the mesh network |
| Mesh Point Name | Displays the name of each configured mesh point in the mesh network |
| Root | A root mesh point is defined as a mesh point connected to the WAN and provides a wired backhaul to the network |
| Name | Unique name of each configured mesh point in the mesh network |
| MAC | MAC Address of each configured mesh point in the mesh network |
| Hostname | Administrator assigned hostname for each configured mesh point in the mesh network |
| Configured as Root | A root mesh point is defined as a mesh point that is connected to the WAN and provides a wired backhaul to the network |
| Is Root | Indicates whether the current mesh point is a root mesh point |
| Destination Address | The destination is the endpoint of mesh path. It may be a MAC address or a mesh point ID |
| Root MP ID | Lists the interface ID of the interface on which the next hop for the mesh network can be found |
| Interface ID | Uniquely identifies an interface associated with the ID. Each mesh point on a device can be associated with one or more interfaces |
| Next Hop IFID | Identifies the ID of the interface on which the next hop for the mesh network can be found |
| Root Bound Time | Displays the duration this mesh point has been connected to the mesh root |
| IFID Count | Displays the number of IFIDs associated with all the configured mesh points in the network |
| Next Hops Use Time | Lists the time when the next hop in the mesh network topology was last utilized |
| Root Hops | Number of hops to a root and should not exceed 4 in general practice. If using the same interface to both transmit and receive, then you will get approximately half the performance every additional hop out |
| Radio Interface | Lists the radio interface on which the mesh point operates |
| Name | Displays the name of each configured mesh point in the RF Domain |
| Destination Address | The destination is the endpoint of mesh path. It can be a MAC address or a mesh point ID |
| Destination | The MAC Address used by the interface on the neighbor device to communicate with this device. This may define a particular radio or Ethernet port that communicates with this device over the mesh |
| Is Root | A root mesh point is defined as a mesh point that is connected to the WAN and provides a wired backhaul to the network |
| MiNT ID | Displays the MiNT Protocol ID for the global mint area identifier. This area identifier separates two overlapping MiNT networks and need only be configured if the administrator has two MiNT networks that share the same packet broadcast domain |
| Next Hop IFID | The Interface ID of the mesh point that traffic is being directed to |
| Mobility | Displays whether the mesh point is a mobile or static node. Displays True when the device is mobile and False when the device is not mobile |
| Metric | A measure of the quality of the path. A lower value indicates a better path |
| State | Indicates whether the path is currently Valid or Invalid |
| Binding | Indicates whether the path is bound or unbound |
| Timeout | The timeout interval in seconds. The interpretation this value will vary depending on the value of the state. If the state is Init or In Progress, the timeout duration has no significance. If the state is Enabled, the timeout duration indicates the amount of time left before the security validity check is initiated. If the state is Failed, the timeout duration is the amount of time after which the system will retry |
| Sequence | The sequence number also known as the destination sequence number. It is updated whenever a mesh point receives new information about the sequence number from RREQ, RREP, or RERR messages that may be received related to that destination |
| Recommended | Displays the root that is recommended by the mesh routing layer |
| Root MP ID | The MP identifier is used to distinguish between other mesh points both on the same device and on other devices. This is used by a user to setup the preferred root configuration |
| Next Hop IFID | The IFID of the next hop. The IFID is the MAC Address on the destination device |
| Radio Interface | This indicates the interface that is used by the device to communicate with this neighbor |
| Bound | Indicates whether the root is bound or unbound |
| Metric | Displays the computed path metric between the neighbor and their root mesh point |
| Interface Bias | This field lists any bias applied because of the Preferred Root Interface Index |
| Neighbor Bias | This field lists any bias applied because of the Preferred Root Next-Hop Neighbor IFID |
| Root Bias | This field lists any bias applied because of the Preferred Root MPID (mesh point ID) |
| Subscriber Name | Lists the subscriber name is used to distinguish between other mesh point neighbors both on the same device and on other devices |
| Subscriber MP ID | Lists the subscriber ID to distinguish between other mesh point neighbors both on the same device and on other devices |
| Group Address | Displays the MAC address used for the Group in the mesh point |
| Neighbor MP ID | The MAC Address that the device uses to define the mesh point in the device that the neighbor is a part of. It is used to distinguish the device that is the neighbor |
| Neighbor IFID | The MAC Address used by the interface on the neighbor device to communicate with this device. This may define a particular radio or Ethernet port that communicates with this device over the mesh |
| Root MP ID | The mesh point ID of the neighbor's root mesh point |
| Is Root | A root mesh point is defined as a mesh point that is connected to the WAN and provides a wired backhaul to the network. Yes if the mesh point that is the neighbor is a root mesh point or No if the Mesh Point that is the neighbor is not a root |
| Mesh Root Hops | The number of devices between the neighbor and its root mesh point. If the neighbor is a root mesh point, this value will be 0. If the neighbor is not a root mesh point but it has a neighbor that is a root mesh point, this value will be 1. Each mesh point between the neighbor and its root mesh point is counted as 1 hop |
| Resourced | Displays whether the mesh point has been resourced or not. The Mesh Connex neighbor table can contain more neighbors than the AP supports. If the neighbor is resourced, it will take away a one of the resources for a wireless client device to be used for meshing. Displays True when the device is resourced and False when the device is not |
| Link Quality | An abstract value depicting the quality of the mesh link between the device and the neighbor. The range is from 0 (weakest) to 100 (strongest) |
| Link Metric | This value shows the computed path metric from the device to the neighbor mesh point using this interface. The lower the number the better the possibility that the neighbor will be chosen as the path to the root mesh point |
| Root Metric | The computed path metric between the neighbor and their root mesh point |
| Rank | The rank is the level of importance and is used for
automatic resource management
| Age | Displays the number of milliseconds since the mesh point last heard from this neighbor |
| Name | Unique name of each configured mesh point in the network |
| Destination Address | Endpoint of a mesh path. It can be a MAC address or a mesh point ID |
| Radio Interface | Indicates the interface that is used by the device to communicate with this neighbor |
| Interface ID | The IFID uniquely identifies an interface associated with the MPID. Each mesh point on a device can be associated with one or more interfaces |
| State | Displays the link state for each mesh point:
| Timeout | Displays the maximum value in seconds that the link is allowed to stay in the In Progress state before timing out |
| Keep Alive | Indicates whether the local mesh point will act as a source to authenticate the link and not let it expire |
| Destination Address | The destination is the endpoint of mesh path. It may be a MAC address or a MPID (mesh point ID) |
| Proxy Address | Displays the MAC Address of the proxy used in the mesh point |
| Age | Displays the age of the proxy connection for each of the mesh points in the RF Domain |
| Proxy Owner | The owner (MPID) is used to distinguish the device that is the neighbor |
| VLAN | The VLAN ID used as a virtual interface with this proxy. A value of 4095 indicates that there is no VLAN ID |
