clear cos reference irl
Use this command to clear one or all Class of Service inbound rate limiting reference configurations.
Syntax
clear cos reference irl {all | group-type-index reference}
Parameters
all | group-type-index Clears all non-default inbound rate limiting reference entries or a specific entry. Valid group-type entries are in the form of group.type. Group can be 0 - 11, with 0 designating the default group, and 1 - 11 reserved for user-defined groups. Port type can be 0 - 1 for the S- and K-Series and 0 for the 7100-Series.
reference Specifies a reference number of the entry to be cleared.
Defaults
None.
Mode
All command modes.
This example shows how to clear all Class of Service inbound rate limiting reference entries:
System(rw)->clear cos reference irl all
