clear igmp input-filter
Use this command to clear an input filter.
Syntax
clear igmp input-filter filter-id [rule-id]
Parameters
filter-id The ID of the filter that you want to clear. Possible values are 1–16.
rule-id The ID of the rule that you want to clear. Possible values are 1–8.
Defaults
None.
Mode
All command modes.
This example shows how to clear input filter 1 rule 1.
System(su)->clear igmp input-filter 1 1
