clear radius-snooping flow
Use this command to clear all entries or the specified index entry from the RS flow table.
Syntax
clear radius-snooping flow {all | index}
Parameters
all Specifies that all flow table entries are to be cleared.
index Specifies a specific flow table index entry to be cleared.
Defaults
None.
Mode
All command modes.
Usage
Use the index value to clear flows for a particular port.
This example clears all flow table entries:
System(rw)->clear radius-snooping flow all
This example clears the flow table entry for index 5:
System(rw)->clear radius-snooping flow 5
