clear port broadcast
Use this command to reset the broadcast threshold and/or clear the peak rate and peak time values on one or more ports.
Syntax
clear port broadcast port-string {[threshold] [peak]}
Parameters
port-string Specifies the port(s) on which broadcast settings will be cleared.
threshold (Optional) Clears the broadcast threshold setting.
peak (Optional) Clears the broadcast peak rate and peak rate time values.
Defaults
None.
Mode
All command modes.
This example shows how to clear all broadcast suppression settings on ports ge.1.1 through 5:
System(rw)->clear port broadcast ge.1.1-5 threshold peak
This example shows how to clear threshold broadcast suppression settings on ports ge.1.1 through 5:
