set inlinepower management
Use this command to set the PoE management mode on a specified module.
Syntax
set inlinepower management {realtime | class} module-number
Parameters
realtime Manages power based on the actual power consumption of the ports.
class Manages power based on the IEEE 802.3af definition of the class upper limit.
module-number Specifies the module on which to set the PoE management mode. If you are configuring this value on an S-Series SSA, use 1 as the module number.
Defaults
None.
Mode
All command modes.
This example shows how to set the PoE management mode to “class” on module 1:
System(rw)->set inlinepower management class 1
