show sla entry detail
Use this command to display the configuration and scheduling information of the selected IP SLA entry.
Syntax
show sla entry entry detail
Parameters
entry The number of the IP SLA entry.
Defaults
None.
Mode
All command modes.
System(su)->show sla entry 2 detail
Entry:                             2  Type:                             echo
Collections:                       2  Probe:                     sla-timing1
Destination:                 3504::1
Distribution count:                0  Distribution interval (ms):         25
History collections:               0  History wrap:                      off
History bucket count:             15  History ageout (minutes):            0
History bucket type:          static  History bucket depth (samples):     16
Monitor path count:                2  Monitor hop count                    4
Scheduling
Start-time:      2012-10-11:20.00.12  Recurrence (seconds):              300
Repetitions:                       2  Duration (seconds):                120
Frequency (seconds):              30  State:                         Running
Status:
  Test 2 of 2 ends in 89 seconds
Displayed 1 sla entry
