clear mpls ldp neighbor
Use this command to reset an LDP session with the specified or all neighbors.
Syntax
clear mpls ldp neighbor [vrf vrf-name] {ip-address | all}
Parameters
vrf vrf-name (Optional) Specifies the name of the VRF to which the command will be applied
ip-address Specifies the neighbor IP address associated with the session to be cleared.
all Specifies that all LDP sessions for this router context are cleared.
Defaults
  • If the VRF option is not specified, the global router context is applied to this command.
Mode
Global router or named VRF global configuration mode.
This example shows how to reset all LDP sessions for VRF vpnA:
System(rw)->router vpnA
System(su-vpnA)->configure
System(su-vpnA-config)->clear mpls ldp neighbor vrf vpnA all
