Use this command to match a route‘s metric cost value or a range of metric cost values.
| cost | Specifies a metric cost value to match against the metric cost value of the packet for this route filter. Valid values: 1 - 4294967295. |
| range min-cost max-cost | Specifies a range of metric cost values to match against the metric cost value of the packet for this route filter:
None.
Route-map filter configuration.
Apply the filter route-map using the distribute-list route-map in command in OSPF router configuration command mode to prevent route matches from entering the OSPF routing table.
The “no” form of this command removes the match between a metric cost and this route-map.
This example shows how to match a packet cost metric against the specified value of 100:
System(rw-config)->route-map filter ospf1 System(rw--config-fltr)->match metric 100
This example shows how to match a packet cost metric against the range of metric values from 100 to 200:
System(rw-config)->route-map filter ospf1 System(rw--config-fltr)->match metric range 100 200
Print
this page
Email this topic
Feedback
