Export an RSA Key
The keys utilized by a controller, service platform or access point can be exported to an external resource for archive and future use.
Export the key to a redundant RADIUS server to import it without generating a second key. If there is more than one RADIUS authentication server, export the certificate and do not generate a second key unless you want to deploy two root certificates.
Use this procedure to export an RSA key.
  1. Go to Devices and select a target device.
  2. Select the Certificates tab.
  3. Select the RSA Keys tab.
  4. Select and configure the parameters as described in .
    Table 1. RSA Keys – Export Parameters
    Parameter Description
    Key Name Enter the name (up to 32 characters) of the RSA key to be exported.
    Key Passphrase Define the key used by both the controller or service platform and the server (or repository) of the target RSA key. Select to view the characters used in the passphrase. Otherwise, the passphrase displays as a series of asterisks (****).
    Path/File Specify the path to the RSA key. Enter the complete relative path to the key on the server.
  5. Select OK to export the defined RSA key.
