Go to Statistics > Wireless, then select a Site in the list.
The Basic pane displays Wireless statistics for the selected Site, in tabular form. Wireless Statistics - Basic List Column Headings describes the type of information displayed under each column in the table.
| Column Heading | Description |
| Name | The administrator assigned SSID for the WLAN. |
| User Traffic | Displays the rate (in kbps) user data is transmitted and received by each WLAN member AP radio. This rate only applies to user data and does not include any management overhead. |
| Management Packets | Displays the total number of management packets transmitted and received by each WLAN member AP radio within the WLAN. |
| Throughput | Displays the data throughput (in bps) within the WLAN. |
| Radio Count | Displays the number of WLAN member AP radios currently in use. |
| Dropped Count | Displays the total number of packets dropped by each WLAN member AP radio during transmission. This includes user data as well as management overhead packets. |
| Error Count | Displays the total number of packets containing errors, received by each WLAN member AP radio. The higher the error rate, the less reliable the connection or data transfer. |
