Logging and tracing involves RASTrace, RASLog, AuditLog, and Syslog.
RASTrace captures low level info which can be used for debugging or troubleshooting issues. Use the rasdecode command to decode the traces collected. You must provide the module ID (-m) and display count (-n) parameters.
Use the tracecfg command to display, clear, and modify the trace configurations such as debug level, number of trace entries, trace dump size, and so on, for any individual module. Use tracecfg -h command from the linux shell for usage information.
RASTrace, RASLog, AuditLog, and Syslog are detailed in the following section of the docuemnt.
