You can customize Opticthresholds or actions by using the threshold-monitor sfp command, which enables you to perform the following tasks.
If you do not provide the Optic type parameters, the default thresholds and actions are used. Optic types, monitoring areas, and default threshold values for the 16-Gbps and QSFP optics are detailed below.
Optic type | Area | Unit | Low | High |
1GSR | Temperature | C | -40 | 100 |
RX power | uW | 8 | 1122 | |
TX power | uW | 60 | 1000 | |
Current | mA | 2 | 12 | |
Supply voltage | mV | 3000 | 3600 | |
Power on hours | Hrs | 0 | 0 | |
1GLR | Temperature | C | -45 | 90 |
RX power | uW | 6 | 501 | |
TX power | uW | 71 | 794 | |
Current | mA | 1 | 45 | |
Supply voltage | mV | 2900 | 3700 | |
1GCOP | Temperature | C | -45 | 90 |
10GUSR | Temperature | C | -5 | 100 |
RX power | uW | 32 | 2000 | |
TX power | uW | 126 | 2000 | |
Current | mA | 3 | 11 | |
10GSR | Temperature | C | -5 | 90 |
RX power | uW | 32 | 1000 | |
TX power | uW | 251 | 794 | |
Current | mA | 4 | 11 | |
10GLR | Temperature | C | -5 | 88 |
RX power | uW | 16 | 1995 | |
TX power | uW | 158 | 1585 | |
Current | mA | 15 | 85 | |
Supply voltage | mV | 2970 | 3600 | |
10GER | Temperature | C | -5 | 75 |
RX power | uW | 10 | 1585 | |
TX power | uW | 135 | 5012 | |
Current | mA | 20 | 120 | |
Supply voltage | mV | 3035 | 3665 | |
40GSR | Temperature | C | -5 | 75 |
RX power | uW | 40 | 1995 | |
TX power | uW | 0 | 0 | |
Current | mA | 1 | 10 | |
40GSRINT | Temperature | C | -5 | 75 |
RX power | uW | 45 | 2188 | |
Current | mA | 1 | 55 | |
Supply voltage | mV | 2970 | 3630 | |
40GESR | Temperature | C | -5 | 75 |
40GLR | Temperature | C | -5 | 70 |
RX power | uW | 21 | 3380 | |
Current | mA | 5 | 70 | |
100GSR | Temperature | C | -5 | 75 |
RX power | uW | 40 | 2188 | |
TX power | uW | 100 | 3162 | |
Current | mA | 3 | 13 | |
100GLR | Temperature | C | -5 | 75 |
RX power | uW | 35 | 3548 | |
TX power | uW | 148 | 5623 | |
Current | mA | 20 | 110 | |
100GPSM | Temperature | C | 0 | 70 |
RX power | uW | 55 | 2818 | |
TX power | uW | 398 | 2818 | |
Current | mA | 30 | 70 | |
Supply voltage | mV | 3135 | 3465 | |
100GCWDM | Temperature | C | -3 | 75 |
RX power | uW | 45 | 2239 | |
TX power | uW | 114 | 2818 | |
Current | mA | 5 | 75 | |
Supply voltage | mV | 3040 | 3560 | |
100GCLR | Temperature | C | 0 | 70 |
100GLRLT | Temperature | C | -5 | 75 |
RX power | uW | 55 | 3548 | |
TX power | uW | 234 | 3548 | |
10GZR | Temperature | C | -11 | 91 |
RX power | uW | 2 | 51 | |
TX power | uW | 316 | 3548 | |
Current | mA | 15 | 130 | |
Supply voltage | mV | 3000 | 3510 | |
1GCWDM | Temperature | C | -9 | 110 |
RX power | uW | 4 | 1000 | |
TX power | uW | 398 | 8310 | |
Current | mA | 2 | 105 | |
Supply voltage | mV | 2800 | 4000 | |
10GDWDMT | Temperature | C | -8 | 73 |
RX power | uW | 1 | 398 | |
TX power | uW | 501 | 1995 | |
Current | mA | 15 | 126 | |
40GER | Temperature | C | -5 | 78 |
RX power | uW | 3 | 2239 | |
Current | mA | 8 | 105 | |
40GLM | Temperature | C | -5 | 78 |
RX power | uW | 17 | 3388 | |
100GESR40GLM | Temperature | C | -5 | 75 |
RX power | uW | 35 | 2188 | |
TX power | uW | 74 | 3467 | |
Current | mA | 2 | 10 | |
100GAOC40GLM | Temperature | C | -5 | 75 |
1GBIDI10KM | Temperature | C | -40 | 95 |
RX power | uW | 11 | 501 | |
TX power | uW | 126 | 501 | |
Current | mA | 3 | 80 | |
1GBIDI40KM | Temperature | C | -40 | 85 |
RX power | uW | 6 | 1000 | |
TX power | uW | 316 | 1000 | |
Current | mA | 0 | 300 | |
Supply voltage | mV | 3130 | 3470 | |
1GBIDI120KM | Temperature | C | -40 | 85 |
RX power | uW | 1 | 200 | |
TX power | uW | 794 | 2512 | |
Current | mA | 0 | 500 | |
1GELX | Temperature | C | -10 | 85 |
RX power | uW | 0 | 5000 | |
TX power | uW | 0 | 5000 | |
Current | mA | 0 | 50 | |
1GFX | Temperature | C | -40 | 85 |
TX power | uW | 126 | 794 | |
1GLHA | Temperature | C | -5 | 85 |
RX power | uW | 2 | 1000 | |
TX power | uW | 794 | 3981 | |
Current | mA | 2 | 90 | |
1GLHB | Temperature | C | -10 | 85 |
1GLX | Temperature | C | -40 | 85 |
RX power | uW | 5 | 1585 | |
Current | mA | 0 | 60 | |
1GLX-1 | Temperature | C | -40 | 85 |
RX power | uW | 10 | 500 | |
TX power | uW | 100 | 500 | |
1GLXDUAL | Temperature | C | -40 | 95 |
RX power | uW | 1 | 158 | |
TX power | uW | 32 | 158 | |
1GLXTAA | Temperature | C | -40 | 85 |
Current | mA | 0 | 90 | |
1GLXTAA-1 | Temperature | C | -10 | 100 |
RX power | uW | 5 | 501 | |
1GSX | Temperature | C | -40 | 85 |
RX power | uW | 31 | 500 | |
1GSXTAA | Temperature | C | -40 | 100 |
RX power | uW | 13 | 1000 | |
TX power | uW | 158 | 501 | |
Current | mA | 0 | 20 | |
1GZRCWDM | Temperature | C | -40 | 85 |
RX power | uW | 5 | 1000 | |
Supply voltage | mV | 3000 | 4000 | |
1GZRCWDM-1 | Temperature | C | -40 | 85 |
1GZRCWDM-2 | Temperature | C | -40 | 85 |
8GELS | Temperature | C | -10 | 85 |
RX power | uW | 12 | 1122 | |
TX power | uW | 250 | 2500 | |
8GLR | Temperature | C | -10 | 85 |
TX power | uW | 144 | 1122 | |
8GSR | Temperature | C | -40 | 125 |
RX power | uW | 10 | 1000 | |
TX power | uW | 100 | 1585 | |
8GSR-1 | Temperature | C | -10 | 85 |
RX power | uW | 49 | 500 | |
10GBIDI | Temperature | C | -40 | 85 |
RX power | uA | 36 | 1122 | |
TX power | uA | 151 | 1122 | |
Current | mA | 0 | 65 | |
Supply voltage | mV | 3100 | 3500 | |
10GBIDI40KM | Temperature | C | -40 | 125 |
RX power | uA | 40 | 1122 | |
TX power | uA | 1585 | 5012 | |
Current | mA | 0 | 285 | |
10GBIDITAA | Temperature | C | -40 | 125 |
TX power | uA | 316 | 1000 | |
Current | mA | 0 | 400 | |
10GCWDM-1 | Temperature | C | -10 | 75 |
RX power | uA | 10 | 1585 | |
TX power | uA | 316 | 1585 | |
10GCWDM-2 | Temperature | C | -10 | 75 |
10GER40KM | Temperature | C | ||
RX power | uA | -10 | 85 | |
TX power | uA | 0 | 5000 | |
10GERDWDM | Temperature | C | -8 | 73 |
RX power | uW | 20 | 1000 | |
TX power | uW | 501 | 3162 | |
Current | mA | 40 | 120 | |
10GERDWDM -1 | Temperature | C | -8 | 73 |
RX power | uA | 20 | 1000 | |
TX power | uA | 501 | 3162 | |
10GERX | Temperature | C | -10 | 85 |
RX power | uA | 0 | 5000 | |
10GET | Temperature | C | -10 | 85 |
10GLR10KM | Temperature | C | -5 | 70 |
RX power | uA | 38 | 1122 | |
10GLRDUAL | Temperature | C | -40 | 125 |
RX power | uA | 6 | 1585 | |
TX power | uA | 100 | 1585 | |
10GLRDUAL -1 | Temperature | C | 0 | 70 |
RX power | uA | 25 | 1120 | |
TX power | uA | 151 | 1120 | |
10GLRMX | Temperature | C | -10 | 85 |
10GLRTAA | Temperature | C | -10 | 90 |
RX power | uA | 16 | 1259 | |
TX power | uA | 126 | 1413 | |
Current | mA | 7 | 100 | |
10GSLRM | Temperature | C | -40 | 125 |
RX power | uA | 6 | 1000 | |
TX power | uA | 100 | 1995 | |
Current | mA | 0 | 75 | |
10GSLRM-1 | Temperature | C | -25 | 95 |
RX power | uA | 10 | 1259 | |
TX power | uA | 158 | 1585 | |
Supply voltage | mV | 2800 | 3800 | |
10GSR300M | Temperature | C | 0 | 70 |
RX power | uA | 10 | 1000 | |
TX power | uA | 126 | 562 | |
Supply voltage | mV | 3140 | 3460 | |
10GSR300M-1 | Temperature | C | -10 | 85 |
RX power | uA | 77 | 500 | |
TX power | uA | 100 | 500 | |
10GSR300M-2 | Temperature | C | -20 | 90 |
RX power | uiA | 10 | 1259 | |
TX power | uA | 160 | 1589 | |
Current | mA | 1 | 20 | |
Supply voltage | mV | 2800 | 3000 | |
10GSR300M-3 | Temperature | C | -5 | 70 |
10GSRDUAL | Temperature | C | -40 | 125 |
RX power | uA | `10 | 1000 | |
TX power | uA | 100 | 794 | |
10GSRDUAL-1 | Temperature | C | -10 | 85 |
10GSRTAA | Temperature | C | -10 | 85 |
10GSRTAA-1 | Temperature | C | -20 | 90 |
10GSRX | Temperature | C | -10 | 85 |
RX power | uA | 32 | 2000 | |
TX power | uA | 126 | 2000 | |
10GUSR100M | Temperature | C | -5 | 85 |
TX power | uA | 316 | 794 | |
10GUSR100M-1 | Temperature | C | -10 | 85 |
10GUSR100MTA | Temperature | C | -5 | 70 |
Supply voltage | mV | 3140 | 3640 | |
RX power | uA | 2 | 251 | |
TX power | uA | 316 | 3548 | |
10GZR80KM | Temperature | C | -10 | 75 |
RX power | uA | 2 | 316 | |
TX power | uA | 794 | 3162 | |
Current | mA | 0 | 127 | |
10GZRCWDM | Temperature | C | -10 | 85 |
10GZRX | Temperature | C | -10 | 85 |
25GER | Temperature | C | -10 | 85 |
25GESR | Temperature | C | 0 | 70 |
RX power | uA | 79 | 1738 | |
TX power | uA | 126 | 1738 | |
Supply voltage | mV | 3140 | 3450 | |
25GLR | Temperature | C | 0 | 70 |
RX power | uA | 52 | 1585 | |
TX power | uA | 200 | 1585 | |
25GSR | Temperature | C | 0 | 70 |
25GSR100M | Temperature | C | 0 | 85 |
RX power | uA | 40 | 1000 | |
TX power | uA | 158 | 794 | |
Supply voltage | mV | 3150 | 3460 | |
40GSRBIDI | Temperature | C | 10 | 70 |
RX power | uW | 170 | 1000 | |
RX power | uA | 45 | 2188 | |
TX power | uA | 0 | 0 | |
100G4WDM | Temperature | C | -10 | 85 |
100GCWDM2KM | Temperature | C | 0 | 70 |
RX power | uA | 71 | 1778 | |
TX power | uA | 224 | 1778 | |
Current | mA | 0 | 100 | |
Supply voltage | mV | 0 | 3450 | |
100GERLT | Temperature | C | -10 | 85 |
100GLR10KM | Temperature | C | 0 | 70 |
RX power | uA | 87 | 2818 | |
TX power | uA | 372 | 2818 | |
Supply voltage | mV | 0 | 3465 | |
RX power | uA | 55 | 3548 | |
TX power | uA | 234 | 3548 | |
100GSR100M | Temperature | C | -10 | 80 |
RX power | uA | 40 | 3467 | |
TX power | uA | 62 | 3467 | |
Current | mA | 0 | 12 | |
100GSRBIDI | Temperature | C | -10 | 85 |
100MBIDI | Temperature | C | -40 | 95 |
RX power | uA | 1 | 40 | |
TX power | uA | 40 | 158 | |
100MFX | Temperature | C | -40 | 85 |
RX power | uA | 62 | 125 | |
100MFX-1 | Temperature | C | -10 | 85 |
100MLX | Temperature | C | -40 | 95 |
RX power | uA | 1 | 200 | |
TX power | uA | 25 | 200 | |
Current | mA | 0 | 80 | |
