Alerts can be set for cpu, memory, and buffer usage.
	 When monitoring is configured, thresholds can be set. When the thresholds are exceeded, actions such as messages can be sent. Logs are saved for periods of time to enable viewing of threshold status.
Support for the custom policy operand is not provided for CPU and memory threshold monitoring.
		   Enter global configuration mode.
			 device# configure terminal
		  To set the memory threshold between 40 and 60 and cause no message to be sent when thresholds are exceeded, enter the
			 threshold-monitor memory command as follows.
			 device(config)# threshold-monitor memory actions none high-limit 60 low-limit 40
		  To adjust cpu usage polling and retry attempts and cause a RASLog message to be sent
			 and collect more diagnostic information when thresholds are exceeded, enter the
			 threshold-monitor cpu command as follows.
			 device(config)# threshold-monitor cpu actions loginfo limit 65 poll 60 retry 10
		  To set the buffer utilization threshold at 75% and polling interval as 130 seconds, enter the
			 threshold-monitor buffer
			 command as follows.
			 device(config)# threshold-monitor Buffer limit 75 poll 130 actions loginfo
