Enabling or disabling CFM
To enable or disable the Connectivity Fault Management (CFM) protocol globally on the devices and enter into the CFM protocol configuration mode, enter the following command.
device# configure terminal
device(config)# protocol cfm
device(config-cfm)#
The no form of the command disables the CFM protocol.
