In the external-collector
telemetry-streaming implementation, your monitored device streams data to one or more collector devices—for monitoring and
analysis.
For each target collector device, you configure a local telemetry collector object
that specifies the following parameters:
One or more telemetry
profiles
IPv4 address/port of the
collector device
Encoding format (Google protocol
buffers (GPB) or JavaScript object notation (JSON))
(Optional) VRF
Activation
The following diagram depicts the many-to-many relationships between profiles and
collectors:
You can specify multiple profiles
in a collector.
You can specify a profile in
multiple collectors.
Profile/collector relationships in
external-collector streaming
The preceding diagram does not depict local
telemetry
collector objects.
