show cfm connectivity
Use the show cfm connectivity command to display the Connectivity Fault Management (CFM) configuration.
The following commands display the received port status tlv state at RMEP.
device# show cfm connectivity
Domain: md1
Index: 1
Level: 7
  Maintenance association: ma5
  MA Index: 5
  CCM interval: 100 ms
  Bridge-Domain ID: 50
  Priority: 7
  MAID Format: Short
    MEP Id: 1
    MEP Port: Eth 1/9
      RMEP  MAC             VLAN/PEER         INNER-VLAN    PORT      STATE
      2     609c.9f5e.4809  19.1.1.1           --            --       OK
For the show cfm command to generate output, you must first enable CFM in protocol configuration mode.
