The following is an example of configuring SFP monitoring.
device# configure terminal
device(config)# threshold-monitor sfp policy custom type 1glr area temperature alert above highthresh-action raslog email
device(config)# threshold-monitor sfp apply custom
To disable threshold monitoring, enter the threshold-monitorsfp pause command.
To re-enable monitoring, enter the no form of the threshold-monitor command.
