By default, the monitoring of the deleted or discarded packets is disabled. You can enable the monitoring of all TM deleted or discarded packets on the SLX device, or all VOQ discarded packets.
This feature is supported only on devices based on the DNX chipset family. For
more information, see
Supported Hardware.
Access global configuration
mode.
device# configure terminal
Access system-monitor TM
configuration mode.
device(config)# system-monitor TM
Configure the threshold interval
to enable the monitoring of all TM deleted packets on the device.
device(sys-mon tm)# delete-packets threshold 10
This example configures the
threshold of 10 TM deleted packets. A threshold of 0 disables the monitoring of
the packets.
(Optional) Configure the logging
interval to monitor all TM deleted packets.
device(sys-mon tm)# delete-packets logging-interval 100
This step configures the
logging interval of 100 minutes. By default, the interval is 60 minutes.
Configure the threshold interval to enable the monitoring of all TM discarded packets.
device(sys-mon tm)# discard-packets threshold 15
This example configures the threshold of 15
TM device-discarded packets. A threshold of 0 disables the monitoring of the
packets.
interval to monitor all TM discarded packets.
device(sys-mon tm)# discard-packets logging-interval 100
Configure the threshold interval to enable the monitoring of all VOQ discarded packets.
device(sys-mon tm)# discard-voq-packets threshold 10
This example configures the threshold of 10
VOQ discarded packets. A threshold of 0 disables the monitoring of the packets.
interval to monitor the VOQ discarded packets.
device(sys-mon tm)# discard-voq-packets logging-interval 100
The following example summarizes the commands in
this procedure.
Use the show system monitor tm
command to display the configuration for the deleted and discarded TM-device packets
or the discarded VOQ discarded packets.
The following example displays the monitoring configuration for the TM-device deleted packets.
device# show system monitor tm delete-packet
Delete packet count monitoring configuration:
Logging-interval : 60 minutes
Threshold : 10 packets
The following example displays the monitoring configuration for the TM-device discarded packets.
device# show system monitor tm discard-packet
Discard packet count monitoring configuration:
The following example displays the monitoring configuration for the VOQ discarded packets.
device# show system monitor tm discard-voq-packet
Discard VOQ packet count monitoring configuration:
