Link level flow control (LLFC) allows a congested receiver to communicate a PAUSE frame to a transmitter to stop data transmission until the congestion is cleared.
Before configuring LLFC on an interface or a port channel, Extreme recommends that you stop the traffic on the interface.
Perform the following steps to configure LLFC.
device# configure terminal device(config)# interface ethernet 3/18 device(conf-eth-3/18)# qos flowcontrol tx on rx on device(conf-eth-3/18)# end device# show qos flowcontrol interface ethernet 3/18 device# copy running-config startup-config
You can display flow control information for all interfaces, a specific Ethernet interface, or a port channel. This information includes the flow control mode, generation (Tx) and reception (Rx) status, and Tx and Rx PAUSE frame counts.
The following example shows how to display the flow control information for all interfaces.
device# show qos flowcontrol interface all Interface Ethernet 0/1 Mode Off Interface Ethernet 0/2 Mode Off Interface Ethernet 0/3 Mode Off Interface Ethernet 0/4 Mode Off ... Mode 802.3x TX RX TX Output Paused RX Admin Admin Frames 512 BitTimes Frames ----------------------------------------------- Off On 0 0
The following example displays the flow control information on a specific interface.
device# show qos flowcontrol interface ethernet 0/18 Interface Ethernet 0/18 Mode 802.3x TX RX TX Output Paused RX Admin Admin Frames 512 BitTimes Frames ----------------------------------------------- Off On 0 0
You can also clear the flow control statistics for all interfaces, a specific Ethernet interface, or a port channel. The following example clears the statistics for all interfaces.
device# clear qos flowcontrol interface all
The following example clears the flow control statistics on a specific interface.
device# clear qos flowcontrol interface ethernet 0/18
