You can increase the egress throughput rate on a Traffic Management (TM) port on 10G and 100G line cards.
On a 10G card, you can increase the rate from 300 Mbps to 13 Gbps. On a 100G card, you can increase the rate from 300 Mbps to 130 Gbps. The maximum speed supported by an interface is 130% of the default interface speed.
If you configured a breakout connector on an Ethernet interface, you can also increase the egress throughput rate on a breakout port.
This feature is supported only on devices based on the DNX chipset family. For more information, see Supported Hardware.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device(config)# interface Ethernet 1/2
  3. Increase the egress throughput rate on the port.
    device(conf-if-eth-1/2)# qos port-speed-up 300000
    In this example, the egress throughput rate on the port is increased by 300 Mbps.
  4. Return to privileged EXEC mode.
    device(conf-if-eth-1/2)# end
  5. Save the running-config file to the startup-config file.
The following example summarizes the commands in this procedure.
device(config)# interface ethernet 1/2
