Configure a Cos-to-traffic class map to use the ingress 802.1p priority values to classify traffic to a specific traffic class (priority queue) and drop precedence.
If a CoS-to-traffic class mutation map is not defined, the default CoS is used as value of the traffic class, and 0 is used for the drop precedence.
  1. Enter global configuration mode.
    device# configure terminal
  2. Create and name a CoS-to-traffic class map.
    device(config)# qos map cos-traffic-class cosTCMap
  3. Map ingress CoS value to the CoS-to-traffic class map traffic-class and drop precedence values.
    device(config-cos-traffic-class-cosTCMap)# map cos 4 to traffic-class 3 drop-precedence 0
    device(config-cos-traffic-class-cosTCMap)# map cos 5 to traffic-class 5 drop-precedence 1
    device(config-cos-traffic-class-cosTCMap)# map cos 6 to traffic-class 6 drop-precedence 0
    device(config-cos-traffic-class-cosTCMap)# map cos 7 to traffic-class 6 drop-precedence 1
    The drop-precedence parameter is mandatory.
  4. Return to privileged EXEC mode.
    device(config-cos-traffic-class-cosTCMap)# end
  5. Verify the configuration.
    device# show qos maps cos-traffic-class
    Cos-to-Traffic Class map 'cosTCMap'
             In-Cos  : 0  1  2  3  4  5  6  7
       TrafficClass  : 0  1  2  3  3  6  6  6
       DropPrecedence: 0  0  0  0  0  1  0  1
The following example summarizes the commands in this procedure.
