CoPP-related Commands
Several commands can help you configure, safeguard, and troubleshoot Control Plane Policing.
Table 1. Configuration commands
Command
How to use for CoPP
ip icmp-fragment enable
Drop ICMP fragment packets before they are used by hackers for Denial of Service (DoS) attacks.
ip option disable
Discard IP packets with options before hackers send such packets to initiate DoS attacks.
ip access-list extended
class-map
match access-group
policy-map
Configure rate limiting actions. For more information, see CoPP Rate Limiting.
ip receive access-group
ipv6 access-list extended
ipv6 receive access-group
Permit or deny unicast and multicast control packets. For more information, see CoPP Discard and Permit for Control Packets.
Table 2. Show commands
Command
How to use for CoPP
show access-list receive
See the configuration for permit and deny rules for control plan protection.
show statistics access-list
See statistics for packets that meet the permit and deny rules configured for control plane protection.
show policy-map control-plane
See the configuration of the policy map attached to a control plane interface.
show interface ethernet inc rate
See whether the control plane is receiving packets at the configured rate.
show qos cpu info
show qos cpu cfg
CPU ports that allow packets into the control plane have limited bandwidth. View the maximum CPU rates and weighted fair queue values for the various VOQ groups.
