You can configure an MPLS QoS EXP-to-DSCP mutation map.
device# configure terminal
device(config)# qos-mpls map exp-dscp expDscpMap
device(exp-dscp-expDscpMap)# exp 0 to dscp 7 device(exp-dscp-expDscpMap)# exp 1 to dscp 23 device(exp-dscp-expDscpMap)# exp 3 to dscp 31 device(exp-dscp-expDscpMap)# exp 4 to dscp 62
device(exp-dscp-expDscpMap)# end
device# show qos maps exp-dscp expDscpMap
exp-dscp map 'expDscpMap'
Exp : 0 1 2 3 4 5 6 7
DSCP : 0 2 4 3 6 4 5 7
Enabled on the following slots:
This example summarizes the commands in this procedure.
device# configure terminal device(exp-dscp-expDscpMap)# exp 0 to priority 7 drop-precedence 0 device(exp-dscp-expDscpMap)# exp 0 to dscp 7 device(exp-dscp-expDscpMap)# exp 1 to dscp 23 device(exp-dscp-expDscpMap)# exp 3 to dscp 31 device(exp-dscp-expDscpMap)# exp 4 to dscp 62 device(exp-dscp-expDscpMap)# end device# show qos maps exp-dscp expDscpMap device# copy running-config startup-config
