  1. In privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Create the class map and access its configuration mode.
    device(config)# class-map c2
  3. Add a match statement to the VLAN.
    device(config-classmap)# match vlan 500
  4. Access global configuration mode.
    device(config-classmap)# exit
  5. Create the policy map and access its configuration mode.
    device(config)# policy-map p2
  6. Add the class map to the policy map and access the policy-class configuration mode.
    device(config-policymap)# class c2
  7. Configure the class map.
    device(config-policymap-class)# police cir 100000 cbs 6000
    This step configures the committed information rate for the class map.
  8. Access global configuration mode.
    device(config-policymap-class)# exit
    device(config-policymap)# exit
  9. Access interface configuration mode for the interface where you want to apply the policy map.
    device(config)# interface ethernet 1/1
  10. Apply the policy map to the interface.
    device(conf-if-eth-1/1)# service-policy in p2
  11. Access global configuration mode.
    device(conf-if-eth-1/1)# exit
  12. (Optional) Apply the policy map globally.
    device(config)# qos service-policy in p2
The following example summarizes the commands in this procedures.
