The egress ACL rate limit feature
supports statistics when the COUNTER-PROFILE-5 counter profile is enabled. The MPLS tunnel statistic also
uses this counter profile.
Important
device# configure terminal
device(config)# hardware
device(config-hardware)# profile counters counter-profile-5
Warning: To activate the new profile config, please run 'copy running-config startup-config' followed by 'reload system‘.You run these commands in steps 5 and 6.
device(config-hardware)# exit
device# reload system
device# show hardware profile counters counter-profile-5
switch type: BR-SLX9540-4
current COUNTERS profile: COUNTERS-PROFILE-5
InLIF - HitCount: 16384
InL4 - FwdDrop: 8192
OutLIF - HitCount: 16384
Egress ACL - VOQ Counters: 8192
_________________________________________________________________
device# configure terminal device(config)# hardware device(config-hardware)# profile counters counter-profile-5 device(config-hardware)# exit device# copy running-config startup-config device# reload system device# show hardware profile counters counter-profile-5
