Priority flow control (PFC) extends the basic IEEE 802.3x based flow control to multiple classes (8 classes). It enables applications that require flow control to coexist on the same link with applications that can manage without flow control.
PFC defines each one of the eight different types of flows that can be subject to flow control. In the case of an Layer 2 network, PFC uses the priority bits within the VLAN tag (IEEE 802.1p) to differentiate up to eight types of flows that can be subject to flow control, each one independently.
PFC can be configured only at the interface level.
PFC is supported only on devices based on the DNX chipset family. For more information, see Supported Hardware.device# configure terminal
device(config)# interface ethernet 0/1
device(conf-eth-0/1)# qos flowcontrol pfc 2 tx on rx on
device(conf-eth-0/1)# end
show qos flowcontrol interface ethernet 0/1
Interface Ethernet 0/1
Mode PFC
TX frames
RX 0 frames
TX TX RX RX Output Paused
CoS Admin Oper Admin Oper 512 BitTimes
0 Off Off Off Off
1 Off Off Off Off
2 On On On On
3 Off Off Off Off
4 Off Off Off Off
5 Off Off Off Off
6 Off Off Off Off
7 Off Off Off Off
This example summarizes the commands in this procedure.
device# configure terminal device(config)# interface ethernet 0/1 device(conf-eth-0/1)# qos flowcontrol pfc 2 tx on rx on device(conf-eth-0/1)# end device# show qos flowcontrol interface ethernet 0/1 device# copy running-config startup-config
