Important
The egress ACL rate limiting feature is not supported on SLX 9150.Consider the following when you configure egress ACL rate limiting:
Device type | Maximum RL class per tower | Maximum RL class per system |
SLX 9540 | 2,000 | 2, 000 |
Filter key | Description |
Port | Egress port of the Layer 2 packets. |
VLAN | VLAN-based rate limit: The VLAN in which the port participates. |
Bridge Domain | Bridge domain-based rate limit: The bridge domain in which the port's logical interface participates. |
VLAN Tag | ACL-based rate limit: The configuration of either the
single tag or the double tags of the traffics on the
egress port is required with the following match:
Ethernet Type | ACL-based rate limit: Ethernet type of Layer 2 packets. It is optional, but assists in restricting packets for egress rate limiting. |
Source MAC | ACL-based rate limit: Source MAC address of Layer 2 packets. It is optional, but assists in restricting packets for egress rate limiting. |
Destination MAC | ACL-based rate limit: Destination MAC address of Layer 2 packets. It is optional, but assists in restricting packets for egress rate limiting. |
