Several types of QoS mutation maps can be applied to Ethernet ports.
Specifying the mutation map used on a port can lead to contradictions if there are other user-defined classes used in the same policy map that have a set CoS action configured. In this case the defined CoS takes priority over the mutation map.
Egress QoS mutation does not apply to SLX 9150 devices.
