Follow these steps to configure a QoS mutation map.
A policy map and a class map have been configured.
Different kinds of mutations can be used depending on the command. For complete information, refer to relevant Command Reference guide. The available commands are cos-mutation, cos-traffic-class, dscp-cos, dscp-mutation, and dscp-traffic-class.
  1. Enter global configuration mode.
    device# configure terminal
  2. Select the policy map.
    device(config)# policy-map policyMap1
  3. Select the class.
    device(config-policymap)# class default
  4. Specify the mutation map.
    device(config-policyclass)# map dscp-cos all-zero-map
    In this example a DSCP-to-CoS mutation is configured.
  5. Return to privileged EXEC mode.
    device(config-policyclass)# end
  6. Verify the configuration.
    device# show run policy-map
     class default
  7. Save the running-config file to the startup-config file.
QoS mutation map configuration example
