Configuring WRED
WRED is configurable on the ingress side to control when to perform a tail drop or Random Early Drop (RED). Follow these steps to configure WRED.
  1. Enter configuration mode.
    device# configure terminal
  2. Create a WRED profile identified as profile 1, set the thresholds, and set the drop probability.
    device(config)# qos red-profile 1 min-threshold 30 max-threshold 60 drop-probability 44
  3. Verify the WRED configuration.
    device(config)# do show qos red profiles 1
    Red Profile 1
            Minimum Threshold: 30
            Maximum Threshold: 60
            Drop Probability: 44
  4. Return to privileged exec mode.
    device(config)# exit
  5. Save the configuration.
WRED configuration example
