Important
The egress ACL rate limiting feature is not supported on SLX 9150/Extreme 8520.You can run show commands from any level of the CLI.
device# show policy-map int e 4/1 Egress Direction : Policy-Map eACLpol Class eACL100 matches 0 packets 0 bytes Police cir 1000000000 Stats: Operational cir:1000000000 cbs:0 eir:0 ebs:0 Conform Byte:161527005348 Exceed Byte:0 Violate Byte:1904690363136
device# show running-config class-map class-map eVLAN100 match vlan 100 ! class-map eVLAN200 match vlan 200 ! class-map eBDpol match bridge-domain 100
device# show policy-map Number of policy maps : 1 Policy-map epol Bound To: Eth 3/1(out) device# show running-config policy-map policy-map epol class eVLAN100 police cir 800000000 ! class eBDpol police cir 1000000000 ! class eVLAN200 police cir 500000000 !
