device# configure terminal
device(config)# qos-mpls map dscp-exp dscpExpMap
device(dscp-exp-dscpExpMap)# dscp 0 to exp 7 device(dscp-exp-dscpExpMap)# dscp 3 to exp 4 device(dscp-exp-dscpExpMap)# dscp 61 to exp 5 device(dscp-exp-dscpExpMap)# end
device# show qos-mpls maps dscp-exp dscpExpMap dscp-exp map 'dscpExpMap'(dscp= d1d2) d1 : d2 0 1 2 3 4 5 6 7 8 9 ------------------------------------- 0 : 00 00 00 00 00 00 00 00 01 01 1 : 01 01 01 01 01 01 02 02 02 02 2 : 02 02 02 02 03 03 03 03 03 03 3 : 03 03 04 04 04 04 04 04 04 04 4 : 05 05 05 05 05 05 05 05 06 06 5 : 06 06 06 06 06 06 07 07 07 07 6 : 07 07 07 07 Enabled on the following slots:
This example summarizes the commands in this procedure.
device# configure terminal device(config)# qos-mpls map dscp-exp dscpExpMap device(dscp-exp-dscpExpMap)# dscp 0 to exp 7 device(dscp-exp-dscpExpMap)# dscp 3 to exp 4 device(dscp-exp-dscpExpMap)# dscp 61 to exp 5 device(dscp-exp-dscpExpMap)# end device# show qos maps dscp-exp dscpExpMap device# copy running-config startup-config
