This feature allows you to take the normalized QoS in-DSCP value of the egressing IP packet, and bind it to an egress interface.
device# configure terminal
device(config)# interface ethernet 0/5
device(conf-if-eth-0/5)# qos dscp-mutation dscpMap
device(conf-if-eth-0/5)# end
device# show qos maps dscp-mutation Dscp-to-Dscp Mutation map 'dscpMap+' (dscp= d1d2) d1 : d2 0 1 2 3 4 5 6 7 8 9 ------------------------------------- 0 : 00 01 02 03 04 05 06 07 08 09 1 : 10 11 12 13 14 15 16 17 18 19 2 : 20 21 22 23 24 25 26 27 28 29 3 : 30 31 32 33 34 35 36 37 38 39 4 : 40 41 42 43 44 45 46 47 48 49 5 : 50 51 52 53 54 55 56 57 58 59 6 : 40 61 62 63 Enabled on the following interfaces: Eth 0/5
device# configure terminal device(config)# interface ethernet 0/5 device(conf-if-eth-0/5)# qos dscp-mutation dscpMap device(conf-if-eth-0/5)# end device# show qos maps dscp-mutation device# copy running-config startup-config
