Applying a Traffic Class to DSCP Map to an Egress Interface
  • A QoS traffic class-to-DSCP map has been configured.
  • For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices, a L2 switch port needs qos remark dscp be enabled before applying “qos traffic class-to-DSCP map”. On L2 switch port “qos remark dscp” cannot be disabled before removing “qos traffic class-to-DSCP map”.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device(config)# interface ethernet 2/2
  3. Apply the configured QoS traffic class-to-DSCP map to the interface.
    device(conf-if-eth-2/2)# qos traffic-class-cos TcDscpMap
  4. Return to privileged exec mode.
     device(conf-if-eth-2/2)# end
  5. Verify the configuration.
    device# show qos maps traffic-class-dscp
              [Note: CoS = Class of Service, TC = Traffic Class, DP = Drop Precedence,DSCP = Differentiated Services Code Point]
      TC-to-DSCP Map: TcDscpMap
      In-TC:  0   1   2   3   4   5   6   7
      Out-DSCP(DP=0): 00  08  16  24  32  40  48  56
      Out-DSCP(DP=1): 00  30  16  24  32  40  48  56
      Out-DSCP(DP=2): 00  08  16  61  32  40  48  56
      Out-DSCP(DP=3): 00  08  16  24  32  40  48  56
      Enabled on the following interfaces: Eth 0/2
  6. Save the running-config file to the startup-config file.
The following example shows how to apply a QoS traffic class-to-CoS map to an egress interface.
